Nombre de messages : 89 Age : 57 Localisation : Grenoble / Londres Mon Brompton: : S2L / M6L / M3L Date d'inscription : 01/04/2011
Sujet: comment dater son B Jeu 25 Aoû 2011, 22:05
quelqun saurait t'il comment dater la fabrication d'un B avec le n° de série
j'ai cherché sur le site mais n'ai pas trouvé (ou bien cherché, mais je ne suis pas doué pour ce genre de trucs)
merci
khalid Habitué du coin
Nombre de messages : 282 Age : 60 Localisation : marrakech Mon Brompton: : M6R Date d'inscription : 24/05/2011
Sujet: Re: comment dater son B Jeu 25 Aoû 2011, 22:18
1008xxxxx veut dire année 2010 mois 08 0907xxxx veut dire année 2009 mois 07
c'était la réponse de BROMPTON à MICHAEL POUR LA traduction on peut utilisé saint google translate
Bonsoir à tous, voici la réponse que je reçois de chez Brompton : Hi Michael,
Thank you for your enquiry but I am afraid I cannot look up the age from the BS (British Standard) number as we do not keep this information on file.
We can give you the bikes age if you can let me know either the frame or serial number for the bike I should be able to look this up for you. To be clear the frame number, currently 6 digits long, is stamped onto the part between the bottom of the seat tube and rear hinge facing upwards and looks like this –
Then the serial number is 10 digits long; the first 2 numbers are the year of production, the second 2 the month and the last 6 are sequentially raised through our production. This is written on the silver sticker on the seat tube at the back and looks like this –
Once we have the serial or frame number we can give you all the information regarding your bike.
I hope this helps.
Kind Regards,
Nikita Nolan - Sales Administrator
From: Michel Giacomelli [mailto:giacomelli.michel@gmail.com] Sent: 07 June 2011 23:35 To: Info Subject: Brompton Bicycle | Enquiry from Michel Giacomelli
Hello, I bought used a Brompton and I read the following information about the course: 153053 BS6102 PART 1 Can you tell me what year it was built and what are its characteristics? In advance thank you Michael Giacomelli
Sujet: Re: comment dater son B Jeu 25 Aoû 2011, 22:33
merci
pour cela il suffit d'écrire date de naissance devant la case Pour faire vos recherches sur le BromptonForum et cliquer sur rechercher
B-Frog Habitué du coin
Sujet: Re: comment dater son B Ven 26 Aoû 2011, 08:52
